Hello from Germany and Thank you @All Supporters for you're great Work
I'll Hope you're can Help at my Problem.
On my TRENDnet DIN-Rail 16 Port PoE+ Switch I have 8 IP PoE Cam's working (2x Hikvision DS-2CD2543G0--IS , 6x Mini IP PoE Sony 335).
They're Connectet on Hikvision NVR DS-7616NI-I2 and Live View of all Cam's are working fine.
The Problem is:
Only Motion Detection on Hikvision Cam's working and NVR would Recording.
On my 6 Birdwatching Cam's (Sony335) just Motion Detection shown as Log Entry in Alarm History directly in IP Cam.
The Hikvision NVR didn't start Recording, No Motion Detect, No Alarm, No Log Entry.
Is it a Protokoll / Configuration Problem ? What's going wrong ?
Thank you
Best Regrads from Germany
The Problem is:
Thank you
