buddha1988 n3wb Jan 11, 2025 5 0 Papua New Guinea Jan 16, 2025 #1 Hi Team, I deleted my post by mistake. Sorry. I can't access the camera from the mobile app. I have Vstarcam NVR and I have allowed the internet connection but my NVR is still showing (offline). How can I fix this.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,140 Alabama Jan 16, 2025 #2 Did you enable P2P in the settings?
buddha1988 n3wb Jan 11, 2025 5 0 Papua New Guinea Jan 16, 2025 #3 TonyR said: Did you enable P2P in the settings? Click to expand... I can't remember P2P in the setting. if possible so can you send me a screenshot so i can enable P2P
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,140 Alabama Jan 16, 2025 #4 buddha1988 said: I can't remember P2P in the setting. if possible so can you send me a screenshot so i can enable P2P Click to expand... I don't have that NVR. Chapters 8 & 9 of the manual have instructions.
buddha1988 n3wb Jan 11, 2025 5 0 Papua New Guinea Jan 16, 2025 #5 TonyR said: I don't have that NVR. Chapters 8 & 9 of the manual have instructions. Click to expand... There is no option to turn on the cloud (P2P).
buddha1988 n3wb Jan 11, 2025 5 0 Papua New Guinea Jan 16, 2025 #6 TonyR said: I don't have that NVR. Chapters 8 & 9 of the manual have instructions. Click to expand... If you look at my NVR screenshot, you will see that there is no option to enable cloud (P2P). Reactions: TonyR
buddha1988 n3wb Jan 11, 2025 5 0 Papua New Guinea Jan 17, 2025 #7 NVR Brand Name is Vstarcam. Device Model is (N82009-5) Last edited: Jan 17, 2025
Flintstone61 Known around here Feb 4, 2020 7,456 12,068 Minnesota USA Jan 17, 2025 #8 it's garbage. get something better. Reactions: bigredfish and TonyR
