NVR Baseline Firmware_NVR(-K1 series)_ML_STD_V3.4.92 170228 released
alastairstevenson
Staff member
Oct 28, 2014
16,530
7,303
Scotland
Version 3.4.92 of the Hikvision NVR firmware has been released for K1, K2, K4, I-series and E-series NVRs.
Hangzhou Hikvision Digital Technology Co. Ltd.
Actual code changes and improvements - well, that remains to be seen.
The same release notes for all:
  • Software Name:
  • Software Size:
  • Software Description:
    Warning Notice:
    WARNING: Please note that this firmware will not support HiDDNS. If you use the HiDDNS service, you must convert to our new Hik-Connect service before performing this firmware upgrade. Before proceeding, make a record of your devices’ IP addresses and ports information. Then register a new Hik-Connect account by using the Web portal at www.hik-connect.com or Hik-Connect mobile app, iVMS-4500 from the IOS App store/Google Play. For more details, please kindly go to Hangzhou Hikvision Digital Technology Co. Ltd..
    Support Models:
    DS-7604NI-K1/4P DS-7604NI-K1
    Main Updates:
    1. Remove HiDDNS, IPServer;
    2. Newly add Hik-Connect service, support Hik-Connect domain and alarm push service;
    3. Hik-Connect is disabled as default
    4. Verification code creation required when enable Hik-Connect service at the first time;
    5. Other changes
    For more details, please refer to the corresponding firmware release notes.
