Brand new to all this, so any detailed help would be super appreciative
Building a home that's approximate 5000 sqft, builder prewired for all tv locations and external cameras with Cat6/Coax wiring to the utility room (front of the house).
I wanted to setup modem (CM1000) and router (Asus RT AX) in living room since it's in the middle of the house and would have the most reach. However, I just bought Lorex POE camera system and it says that the NVR must connect to router directly. However, I assume that I don't have that option since CaT6 wiring for external cameras are in utility room, so this NVR has to be in utility room as well, so that also means my router and modem must be in utility room if I don't want to run any wires throughout my home (living room has high ceiling so it would be quite the process to run additional wires). Am I missing something?
Should I buy a different camera system, but I assume all POE powered cameras have the same issue?
Any and all advice would be much appreciated in order for me to have my NVR in utility room to connect to existing camera wiring but have my router in living room without installing new wires.
