Hi
I can set the Line crossing alerts directly on the camera when I log into the camera directly but when I look at the NVR menu there is no "enable VCA" OR VCA anywhere in the menu.
Does this mean the NVR will not be able to send /forward push notification from the camera?
If I try and enable Alarms on the ivms 4500 it says " not supported on this device"
Current Firmware : 2.2.5 build 170519
Thanks
Thanks
