Hi all,
I set up the Annke H800 system (h800-8ch-system HIKVISION) everything works fine.
Then I tried to add couple 4 more Laview Cam ( laview saturn series 4k UltraHD 8MP Dahua) to the Annke NVR. After adjusting the settings on the Laview Cam it show up on the NVR. But when I tried to view it on the Annke Connect App, only Annke Cams work, not the Laview cams. Seem like the app doesn't know to connect to the Laview cam. Is there a way to manually adjust the settings on the app for it to also work with Laview cams?
Note: Laview cams connected directly to NVR POE port using ONVIF
Thank you!
Thank you!
