- May 11, 2015
- 180
- 17
Hi All, I've recently installed 4 Hikvision DS-2CD2332 2.8mm 1080p POE cameras, and have been futzing with both the iVMS4200 and Blue Iris software, trying to figure out what would be the better of the two for a PC based NVR solution.
The iVMS software doesn't use near the PC resources of that of blue iris, however I've found that the HikVision software keeps saying "Can't find record file" after recording about 100 instances of motion. The blue iris software, while much more stable (I'm using the eval version for another few days before it craps out) works great, but doesn't do the pre-recording and seems to lag for about 1-2 seconds before triggering on motion.
My NVR system is a Quad Core i5 4400 series, 16GB of RAM, 120GB SSD for Windows/Blue Iris, and a 1TB Seagate Surveillance Drive (SATA) for the data files storage, with 4 cameras going at full 30fps, the system under blue iris is about 75% utilized, where as the iVMS software, only about 25%.
Suggestions on which software is better, more reliable? or should I just scrap the whole PCNVR based idea and go with a regular POE NVR instead? I'm a network engineer by trade, so naturally I chose the PC route instead because of my geekability... was this a mistake?
Thx in advance for any feedback/advice.
