Ready to pull the trigger on a 12-16 cam BI setup, all POE. Nothing is purchased yet except one cam for testing purposes. I have an existing home wired/wifi network which consists of modem>router>unmanaged switch>cat5e. I understand I will need a POE switch that all the cameras will connect to. Does it matter if the POE switch is managed or not? Should my other existing switch be managed?? I am also confused as to how the BI PC physically connects to my POE switch and my existing network at the same time or if it would even need to??? I would prefer everything be hard wired if possible.
Also, what is the preferred hard drive setup for the recordings on this type of system???? If NAS, where would that connect to the network?????
I am looking for this to not only function properly but also be as secure and reliable as possible. Thoughts on anything else I maybe overlooking with regards to those goals would be greatly appreciated.
