E Erwann n3wb Jan 3, 2019 9 0 Singapore Jan 29, 2019 #1 Hi, is it possible to use POE switch with an NVR with no built-in POE to connect POE IPCam?
T tigerwillow1 Known around here Jul 18, 2016 4,736 10,772 USA, Oregon Jan 29, 2019 #2 That's how it's usually done. The alternative is to run a 12 volt power line to the camera. Reactions: Erwann, aristobrat and mat200
A aristobrat IPCT Contributor Dec 5, 2016 2,979 3,179 Jan 29, 2019 #3 Erwann said: is it possible to use POE switch with an NVR with no built-in POE to connect POE IPCam? Click to expand... Usually folks connect their NVR into one of the ports on the PoE switch, and then use another port on the PoE switch to connect it to their regular network. Reactions: Erwann
