Hi all,
I have just received an unbranded Dahua NVR5216-4KS2 courtesy of Andy.
It's a well made, solid looking unit and a great spec.
Unfortunately it is also very loud, infact it is much loader than my HTPC, TV and Humax box all combined. This is currently unacceptable to both me and my wife.
My noise levels according to a, probably unreliable, app on my phone...
Noise levels with NVR OFF/ON: (min 35/50db) (avg 39/59db) (max 48/65db)
The majority of the noise seems to come from the internal power supply. Apparently some NVRs have an external power supply, I maybe should have bought one with an external power supply?
I tempory disconnected the case fan, whilst problem solving, and it made no noticeable difference to noise. The HDD isn't the problem either so it must be the power supply fan.
The power supply fan is ADDA branded, see spec at bottom of this post.
I only have one camera ( 2mp starvis IPC-HDW5231R-ZE) currently connected, as I'm just starting my CCTV install.
Temperatures:
I can't find a temperature gauge on the NVR, but the power supply feels like very cool to touch.
I've read on this very informative forum, that some NVRs can control the fan speed. Unfortunately mine doesn't have the "Self Adaption/Full Speed" option. I don't think this is the problem though, as the power supply fan only appears to have 2 (red and black) wires. I assume this means the PSU fan can only be on or off, unlike the 4 wire case fan?
I've been looking at my options to fix the noise. Here are my ideas:
1) Move the NVR out of the front room and probably into my server cabinet in a cupboard.
Cons:
*I would need to add some simple sound proofing to the cabinet/cupboard as it would be heard otherwise.
*I wouldn't be able to view the camras on my living room TV with powering up my PC or some other hack.
Cost: the insulation, probably less than £30
2) Replace the power supply fan with something quieter. Like this fan by Gelid...
GELID Solutions | SILENT 6
This fan's spec sheet claim to be 24dBA compared to the original fan of 28.8dBA.
It also claims to move 16CFM compared to the original 14.2CFM
Cons:
*Will certainly void any warranty (not sure how good a warranty from China is anyway)
*Time consuming
Cost: about $6 or less than £10 buying in the UK
3) Reduce the power going to the power supply fan.
This is by far the easiest and cheapest solution. I'd simply order a cable that reduces the power from 12V to 9V, or 12V to 5V and plug it in.
Something like this...
Phobya - Speed Reduction Cable - 3pin Molex - 12V to 7V - Black Sleeve https://www.amazon.co.uk/dp/B004CLCNBC/ref=cm_sw_r_cp_apa_vZCWBbM06E8R8
Cons:
Would reduce the airflow through the PSU. Personally I don't see why it needs as much airflow as it has. The PSU is cold to touch after 24h use. It's only powering one hard drive (soon to be 2x 6tb hdd) and 1 camera (soon to be 12x IPC-HDW5231R-ZE.)
It's not going to be powering the cameras, I have a POE plus switch for that.
4) Simply insulating the NVR (inside and/or outside) with sound proofing material.
I ruled this idea out almost immediately as the fan blows through a vent and this is where most of the noise comes from. Obviously you can't insulate the vent.
Cons:
*Not likely to reduce the noise
Any help, ideas or advice would be much appreciated. Have you tried, or thinking about trying, any of the above options?
Original fan specification. The manufacturers spec seems slightly different to the Amazon listing...
Thanks,
Oliver
Temperatures:
Cons:
Cons:
*Time consuming
Cons:
Cons:
Thanks,
Oliver
