What did I do wrong
If so, go to BI's built-in Help (the big "?"), "Clip Playback and the Viewer window" on page 85 , note the speaker icon in upper right; it should be green and volume slider pulled to the right to increase playback volume. Insure clip playback speed is X1, insure speaker is not muted in Windows and volume is up (lower right of Windows taskbar, even when BI is closed).I thought i was working before but now is not
However, if I want to watch all the cameras in playback simultaneously, when I go to the "tile" playback - where I can see all my cameras during playback at once -
Find Attached snippetsNeglected to post screenshots of your configurations.
Thanx tony it is volumed up and also I have found the issue is a little different than original post see additional response that I posted to other member today.+1^^.
It's a head-scratcher, alright.Find Attached snippets
What my 18 year old found out is that all 6 cams have sound during live play which she found by shutting sound off one cam at a time
All cams have sound during clip reviews(playback) except Cam 1 or Cul desac has no sound during clip review
So my original post was incorrect I only have issue with no sound on cam 1 when in clip review mode.
My audio is turned on both on laptop and also in BI
I'd try deleting cam 1 then re-adding.
[/QUOTE
I thought that also just wanted to check Also may be that will fix my time challenge it appears that lap top clock is correct but camera clack did not change at day light savings spring forward
So now all my clip times are off by 1 hour
Should I start another post on that challenge.
Thanx,
This "tile" playback you speak of... this is not clear to me, obviously. And neither is "where I can see all my cameras during playback at once".
How about some screenshots?
One of this "tile" and more?
I want to help and am fairly familiar with BI after 6 years but I cannot picture your issue.![]()
