No Signal Under BlueIris Only For LPRs.
tech101
1,550
2,308
SF BayArea, USA
Hi I am noticing no signal number are really high for two cameras and they are my LPR under BI.. Now I am thinking this is being caused by since I am also using OPENALPR to tag plates.. And since both are using the stream could be the reason..
How ever whats funny is even though BI says no signal for some thousands of times the video is fine all the way thru no issue with the video recording of BI or not that I see anything wrong with it apart from that BI number... even live view is just fine.
That is why never have bothered about it but again thought might as well check with you guys.. and see what you think it could be..
Both camera are the IPC-HFW5231E-Z12
My LPRs did that to, especially at night. I think the black image is mistaken by BI as a lost signal. Like you, I can watch live and playback when it shows signal was lost and it is all present.
Make sure under watchdog that the "interpret monocrome as loss of signal" is unchecked - that just about eliminated mine showing loss of signal.
You can turn watchdog off and that will eliminate it showing those errors if you get annoyed seeing those large numbers.
og that the "inte
Thank you So much Wittaj. Learned something new I think you nailed it it must be the black image.. now that I think about it. Also I did find my intepret monochrome video for those two cameras are checked.
as per your recommendation unchecking them..
UN-checked it for both of the cams now. Also In addition Resetting the stats to see how it does now.
Thank you so much @wittaj Once again !! I think this will do it.. Thank you thank you !! Have a great weekend !
a side note.....
Private ip addresses. Local IP addresses. These addresses are NOT used by the internet. They are for your local home/business network.
10.0.0.0 to 10.255.255.255
172.16.0.0 to 172.31.255.255
192.168.0.0 to 192.168.255.255
There is no reason to redact local ip addresses when posting.
a side note.....
Correct. I just did it since I like the tool of the screenshot. LOL no other reason but agree they are not publicly routable
