catcamstar
- Jan 28, 2018
- 1,656
- 1,196
Answer 1: as all is working well on your mobile, I suspect a cabling problem. Can you hook up your vth with a premade cable to the POE switch. Preferably on another free POE port. Does it then work well? I bet it does!
Answer 2: this is 100% identical as viewing your in-house IP Camera's over WAN/4G/5G: deploy a VPN server (eg on your home router (netgear/asus/ubiquity) or on a pc (raspberry pi)), open a VPN tunnel from your mobile (always on) and off you go. When you receive the notification, just press it and hoppaaa, off you go!
Good luck!
CC
Good luck!
CC
