CapeData BIT Beta Team Jul 27, 2016 67 11 Florida Jan 29, 2019 #1 There is no audio when playing recorded clips in the internal player. If I play the clip in an external player, I hear the audio. Any ideas?
fenderman Staff member Mar 9, 2014 36,891 21,411 Jan 29, 2019 #2 CapeData said: There is no audio when playing recorded clips in the internal player. If I play the clip in an external player, I hear the audio. Any ideas? Click to expand... what format are you recording to? make sure the volume is not turned down in the BI player.
CapeData BIT Beta Team Jul 27, 2016 67 11 Florida Jan 29, 2019 #3 I tried both wmv (my default format) and avi. Yes, the BI volume slider is set to max.
fenderman Staff member Mar 9, 2014 36,891 21,411 Jan 29, 2019 #4 CapeData said: I tried both wmv (my default format) and avi. Yes, the BI volume slider is set to max. Click to expand... try BVR which is ideal and most efficient.
CapeData BIT Beta Team Jul 27, 2016 67 11 Florida Jan 29, 2019 #5 Found the "problem". The playback speed was set to 2X. Any speed other than 1X results in no audio. Reactions: fenderman
fenderman Staff member Mar 9, 2014 36,891 21,411 Jan 29, 2019 #6 CapeData said: Found the "problem". The playback speed was set to 2X. Any speed other than 1X results in no audio. Click to expand... yes
