Can you link to a small sample for checking?I can hear the audio on playback but when I download the file from the hikvision browser interface and play it over VLC it has audio
This is the file name "sample video.mp4"What's the filename and extension?
I'd have thought IPCamTalk would be OK with that.This is the file name "sample video.mp4"
Yap here's the zip file. it should be few kbsI'd have thought IPCamTalk would be OK with that.
If it's not huge, just a few MB, you could zip it up and attach.
That sample plays audio OK (sounds like maybe an A/C unit) on players other than the VLC 3.0.16 on this Linux PC.Yap here's the zip file. it should be few kbs
alastair@PC-I5 ~/Downloads $ mediainfo sample.mp4
General
Complete name : sample.mp4
Format : MPEG-PS
File size : 154 KiB
Duration : 4 s 266 ms
Overall bit rate : 295 kb/s
FileExtension_Invalid : mpeg mpg m2p vob vro pss evo
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : [email protected]@High
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 15.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Color range : Limited
Audio
Format : MPEG Audio
Duration : 4 s 200 ms
Compression mode : Lossy
Delay relative to video : 95 ms
Text
Format : RLE
Format/Info : Run-length encoding
Duration : 4 s 0 ms
hmm.. I'm using a mac and I have VLC 3.18.That sample plays audio OK (sounds like maybe an A/C unit) on players other than the VLC 3.0.16 on this Linux PC.
VLC doesn't seem to be able to decode the audio stream.
Do you have any other video players to try?
Does the Mac have a native one built in, for example?
