I had an instance where my DeepStack installation failed. I run it on a separate box since the GPU won't fit into the PC I'm using for BI. It works fine over the network. My Linux installation appears to have upgraded something automatically and DS stopped working as a result. Thus BI would never send out any alerts.
Is there some way to tell BI to send out the alert if DS fails? This seems like a rather dangerous default to just ignore everything if DS is unavailable.
