I have either an OEM Dahua NVR or a generic one "NVR3216" and several IP cams in a business network. All have been in service for several years and I have been running SmartPSS 1.11.0 with no problem on several Win 7 workstations.
We're upgrading network and I'm trying to get SmartPSS 2.3.4 or 2.3.1 going under Win 10. Auto Search under Devices will only find one of the cameras and can't see the NVR. Doesn't help to try to manually add as it never comes online. All devices can be successfully pinged.
Plain and simply, is there a limit to trying to connect to older hardware on the newer version of SmartPSS? I want to say no, because I can remote in from a Win 10 workstation outside the network on a SmartPSS 2.3.1 4/13/2020 build. All cameras are seen and it works fine there. But none of the win10 workstations on the network will connect. I've looked at every screen and setting I can possibly imagine and came here to see if there's something right under my nose. Installer can't be found and current IT ppl have no experience with cams. Any suggestions?
Chaz
Chaz
