Hi all
I've managed to get a camera system up and running from scratch using all the information here. It's taken me a solid 3 or 4 months of research, ordering and setting everything up, but I got there in the end! My brain is fried from scouring forums.
I have a bunch of niggling questions which I think are easy to answer, and don't want to open new threads for these, hope this is OK. I'm not 100% on forum etiquette lol.
Also I have a 940nm illuminator which I will be testing out down the track in case people are interested.
Here is my setup:
NETWORK:
1. I have only configured a LAN connection in the BI app, then use OpenVPN. Is there a way to receive push notifications, or must I configure a WAN connection and use port forwarding? I've heard port forwarding is bad, but then you need it for things like Uptime Watchdog. What is the common setup here?
2. Is it OK to have my phone connected to OpenVPN all day while at work? (if required to receive notifications).
3. Below are default settings on the router, are any of these a concern and should I disable them? I have port forwarding turned off elsewhere.
4. Should I disconnect my home server from the internet? What is normal practice?
5. Apparently in Australia, no mobile network providers offer email-to-sms/mms services. You must subscribe to a 3rd party and pay per msg. Is anyone in Australia running a setup like this and who are you using? Best pricing I have seen is 34c to 39c per MMS, which could quickly snowball out of control if I mess up my trigger/alert settings which is likely lol.
Here is my setup:
- Blue Iris installed on my server PC and BI android app on my phone
- Using CodeProject.AI for LPR.
- OpenVPN on my router
- Cameras are blocked from the internet in my router
- Currently have one each of 5442T-ZE, 5842T-ZE, COLOR4K-T 3.6mm and 5241E-Z12E for testing around the place
NETWORK:
