TL;DR: I have some questions about two cameras. Skip to the bottom.
I hate that things have gotten to the point that I even need to consider security cameras, but there you go. (I'll spare you the details, but we have not yet been broken into or had anything stolen - neighbors have.) I just installed motion detector lights in my driveway and back yard. I bought a dash cam for my car. Now I'm researching security cameras.
I live in a place where the likelihood of bad guys being around is very low. I'm on a cul-de-sac with a brook behind my house, so criminals tend to avoid places like mine. Still, in today's world, you can't be too careful. So I decided it might not be a bad idea to have a camera for the driveway, for two reasons. Our car is parked in the driveway. (My 1948 Chevy show winner is in the garage.) And my house is on the alley where you have to turn 90 degrees to exit. Even if I never have a problem, I may catch someone driving by who messed with my neighbors.
So I bought two Blink cameras. I installed one in our entryway, which is well protected from the weather, and one outside the garage in a well protected location. (Yes, I knew that was not recommended use.) Now, I'm not a novice when it comes to networking and computers, so I managed to get it working even though there was a problem with the firmware and the manufacturer offered to replace it. (After I got it working, the firmware updated automatically and fixed the problem.) But, after two or three days I quickly decided that battery powered cameras were a bad idea. The range of the Blink cams was less than 25 feet (at my house - they claim 100), so the garage cam only worked some of the time, and the Sync Module keep failing and having to be reconfigured to get it working again.
I then began researching. (I've read a ton of posts on this forum.) I've made several decisions.
So, wireless it is. (Yes, I know you guys don't think wireless is the way to go, but that's my call.)
After much research, I have purchased a Skybell camera for the front door. It's American made, connects to the existing wiring for my doorbell and should work well enough to give me more information than I presently have. I should have no problem installing that and getting it up and running.
That leaves the decision for the driveway camera, and that's where I need some help.
I've narrowed my choices down to two cameras:
I have some questions about these cameras.
- I don't want to pull ethernet all over the house, punch holes in the walls and install jacks to get everything working.
- I also don't want wires hanging out of the ceiling, so I'd have to do the jack installs if I went that route.
- I don't want cameras all over the house. This isn't Fort Knox. I want one for the front door and one for the driveway.
- I don't want an NVR. I don't have room for it and I don't want a monitor to watch all the time.
- I want something simple to install and maintain.
- I want something that will alert me when it detects motion, take pictures and/or video and then go back to sleep or at least allow me to ignore it.
- I'm not too concerned about night vision, because the lights will come on when motion is detected.
- I don't care about audio or alarms, so long as I can be notified on my iPhone 6.
- I searched the forum for any information about Ctronics cams and found nothing. Are these decent cameras? How is the support? Keep in mind excellent night vision isn't critical since the flood lights will trigger on motion. However, a car passing by would not trigger the lights. They would be about 25 feet away from the lights and the camera.
- I'm leaning toward the Hikvision, because some on this forum have recommended them.
- Of these two, which would you buy?
- Should I consider another one?
- Which is better? A 4mm lens? Or a 6mm lens? (I've learned that bigger isn't always better.)
- The camera will be mounted to a board at the top of the garage opening and the wires will go through the board into the attic.
- Do cameras normally come with everything you need to connect them? Or do you have to provide the source of power? (IOW, you can't just plug it in to an outlet.)
