Hi all,
Not sure if this is the right location to post this question, but this is my situation and why I've joined.
I bought a Swann NVR/Camera bundle from Costco back in ~2015. The bottom of the NVR has the model # listed s CONVR-B163MP. It is a 16 CH NVR with 8x 3MP bullet cameras. All of the cameras and NVR are up and working fine. My issue is accessing the NVR from my computer.
I have the Android SwannView Plus app which is working fine using a connection via IP address/port 8000. Does not work if I try to use the Swann UID field even taking photo of the 3D barcode. Bottom line - I can view live and playback historically through the app on the phone fine - however the software interface is clunky.
I had an older Windows 7 PC that I had installed the Swann View Plus software on when I bought the NVR and it worked ok. I bought a new computer with Windows 10 and now I cannot get their software to work correctly. It seems to connect to the NVR (I can see my 8 cameras listed, I can see the CPU and network % bars moving on the top right) but I cannot get any live streams to start.
Figuring out that Swann was rebranding Hikvision I went and downloaded HikCentral Professional and installed it. Once I did that I was able to log into my NVR and was able to get video to preview through Internet Explorer (not Chrome or Edge) but only one camera at a time. I was trying to get it working in a newer browser and think I downloaded a newer web client plugin, which gave me the ability to select multiple live views, but since doing that I cannot get any video to start in any web client or the PC software itself. I do however get a little preview of the video if I hover over the camera name.
So it seems like the connection is establishing but something is preventing the stream from starting, maybe a common issue between all of these packages. I have tried turning off the Windows firewall and no change.
I will also note that when I installed HikCentral Professional it warned me at first that the port 554 for the streaming gateway was in conflict. After some digging I found that if I disabled the Windows Media Player Network Sharing Service I could get HikCentral Service Manager to accept 554 and start. Not sure if related to other issues.
Bottom line - I don't need any fancy features or anything, I just want to be able to view my cameras on my computer! Any ideas of what to do??
