fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
It is easy to find parts for any popular system like honeywell. Check out the thread on the ring alarm as well - monitoring is cheap and sensors are plenty.Yep I'm in the market for an alarm system as well, biggest thing I see with most of these systems is that they don't come with enough extra devices for most homes.. and when you do look for the extra devices it's hard to find any for the system. Hoping to find a good wireless system.. I definitely don't mind spending the extra money especially if I'm getting good quality, reliable products. Just something with a good panel, good battery life, window/ door sensors, glass break sensors, motion sensors and a good LOUD siren I can stick near the eves in the attic. If anyone has any recommendations on a system that I can have sent to Ontario Canada containing those above devices I'll gladly check them out!.
