Hello. Thanks for such an informative forum! I have a lot of questions but I'll try to keep it brief (if possible).
I have a semi-old 4 camera system right now with three CNB vandal resistant dome cameras, possibly model # VFL-20S/VFL-21S http://www.cnbtec.com/en/html/product/product.php?seqx_prod=1235 (one CNB above front door, one CNB in front of house by garage/driveway, one CNB on east side of house) and one wireless Lorex LW2231 http://www.amazon.com/Lorex-LW2231-Wireless-Security-Camera/dp/B00D3MJ152 (in backyard). All of them are connected to a Bolide SVR9000S/T4 DVR http://www.bhphotovideo.com/c/produ...4_4_Channel_H_264_Compression_Standalone.html.
I would like to upgrade the cameras to one Huisun Mini PTZ 10X 2MP bullet http://www.aliexpress.com/item/HUIS...-CMOS-Sensor-security-camera/32378494732.html (in backyard) and one Dahua SD22204T-GN 4X 2MP dome http://www.dahuasecurity.com/products/sd22204t-gn-1046.html (in front of house by garage/driveway) or possibly the EYEsurv ESIP-PTZmicro http://www.nellyssecurity.com/camer...atherproof-mini-ptz-with-4x-optical-zoom.html which seems like the same exact camera. I would also like to add more cameras in the future.
Please forgive my ignorance for the following questions:
1) Will I need a NVR for the new setup or will the old DVR work for everything?
2) Is it possible to have one system (2 old cameras) with a DVR and another system (2 new cameras) with a NVR?
3) If a NVR is needed would I need to buy a hard drive for it or could I use the hard drive from the DVR?
4) Would I need a POE switch for the NVR?
5) Would Blue Iris work with this setup (2 new cameras)? If so, would I still need an NVR or POE switch?
6) How often do you have to pay for Blue Iris? Monthly, yearly, once?
7) What kind of wires/plugs etc. would be needed?
8) I've probably overlooked a lot so please fill me in on anything else.
Hopefully that's not too confusing.
Thank you.
Thank you.
