The first time I set up a camera, I messed up and it took me nearly month to fix it, and don't want to go thru that again, so here's a somewhat novice question to make sure I do this correctly.
Set up is - first camera goes to a TP-Link Switch that has 4 POE connections, and then to my router. (No NVR in line.)
Simply want to add a second camera to that TP-Link, and before I set it up, wanted to make sure if I could use the same password I used for the first camera, or should it be different?
Thanks for any advice.
