- Sep 21, 2015
- 5
- 0
Guys,
I want to buy a Hikvision HikVision DS-2CD2542FWD-IS camera (http://www.hikvision.com/en/Products_accessries_209_i5601.html). The power supply for it is listed as PoE. Assuming I have this camera connected through a Cat7 cable to a patch panel (http://www.digitus.info/nl/producte...-6-klasse-e-patch-panel-geschirmt-dn-91608sd/) which then again with a Cat7 cable connects to a switch (http://www.zyxelguard.com/GS1900-24E.asp), will the camera run? Are there any limitations because of this or is it fully equivalent to running it on a normal power supply?
Distance between camera and switch would be 5-15 meters.
Grateful for any input!
