Hi all,
I have an existing camera (cheap/unbranded 2MP) mounted under my eave (2 story house) with an external IR illuminator next to it (I installed this initially to stop spiders building webs over the cameras internal IR (this is disabled now). The image quality at night is quite poor (the day time image isn't too good either) so I'm looking to replace/upgrade it. I use BI as the NVR.
I have attached a picture of the area it currently records, with some dimensions overlaid (basically it's about 41' to the furthest points from the camera at eave level).
I don't know how to chose between focal length/lenses or aperture/etc?
I believe the IPC-Color4K-X / DH-IPC-HFW5849T1-ASE-LED is meant to be a good camera? If so, which version?
Or is there a better choice of camera?
Thanks for all your help
