Hello folks, I've been reading this forum for a few weeks now and plan to add a few cams out of necessity. I run an e-commerce business out of my home (office is the front room overlooking the porch) and had some recent package thefts from my front porch that were awaiting UPS pick-up from my front door. Right now I have added a Ring Pro doorbell (which sucks) to have something until I can get some cams installed.
I have already purchased a Hikvision NVR and a couple of 4mp Hik turrets (one 2.8mm and one 4mm) to get me started. I will eventually add more to monitor the driveway, garage and other areas of my yard. I am also not opposed to buying any other Hikvision cams, which may suit the front porch application better and use these around other places of my home. My main goal with the front porch is to be able to clearly identify subjects at the front door, as well as keep an overall view of the activity around the front door and walkway. I know the covered porch will pose some issues with lighting, but I can add motion lights where needed. I already have a battery powered one above the front door for when the UPS guys come after dark to do package pick-ups, which can easily be moved or taken down. My home is also a single story, so running cable and placing cams to anywhere around the home is not an issue.
Below are some pictures and an overhead plan of the area in question. Any suggestions for placement or alternative Hik cams (2mp, other lens sizes, etc) would be appreciated. Thanks in advance!
