Hi all,
Closing on my first home next week and ordered a DIY alarm system today, next up is surveillance. I work in IT so when I found out about IP cams running over PoE switches, recording to a NAS, etc ..instead of traditional setups I became a lot more interested. The issue I'm having is the more I read the more options I find, and I need input on which is "best" for me.
1. 4 IP cams running to a PoE switch in the attic(I live in CO, hopefully won't have issues with heat), fish a single cable down from the switch to a router. Connect NVR to router. Connect NVR directly to TV in living room via HDMI. Also want to watch cams from bedroom, was thinking a wireless Android box running an app, HDMI from box to TV.
2. Similar to above except no NVR. Instead run Blue Iris on a dedicated laptop, HDMI from laptop to TV, point to NAS. I read about recording only when motion is detected, seems like a great idea to save HDD space. Sounds great on paper, need to research how well it actually works. I'll live in a remote area so there should be very little motion aside from animals.
No sure what else is out there, definitely open to other ideas. Would also appreciate recommendations on brands and such, would like to keep the setup under $1k if possible.
