Background: I am trying to put together a system for a small office building. I will initially have 3 cameras but could increase later to over 4 so am looking at 8 channel NVRs. A key point is that other than initial setup and maintenance needs, which would necessarily be local, ALL viewing, playback, admin, etc. will be remote. My remote viewing, for sake of this thread will be on either a desktop computer or a laptop - not a mobile device, so resolution will not be a limiting factor, only the connection bandwidth will be an issue, and that will be limited by my upload speed at the building site as the internet bandwidth for upload at my site is not great - only 4 Mbps at best.
My experience so far getting answers talking with Security System vendors is not great so I am looking for some answers to questions that have me confused. Because I have several questions I might repeat this background in separate threads but stick to one basic area in each thread. As further background and for a specific system scenario, I am looking at the HikVision DS-2CD2732F-I 3MP, Varifocal, outdoor dome camera, and the HikVision DS-7600NI-E2/8P NVR, but am not committed to this system yet.
Question Area: Main-streams (MS) and sub-streams (SS).
I understand that good IP cameras can send dual streams, one called the main-stream (MS) - usually set at high resolution and a sub-stream (SS) at lower resolution. In the camera settings each can be set also with different resolutions, frame rates, bit rates, etc. but the SS is usually resolution-limited. I also understand that a key purpose for the SS is to enable use for resolution-limited, and/or bandwidth limited viewing remotely.
My questions:
1) Are both streams saved simultaneously (assuming I have enabled the SS)? Or does this depend on the particular NVR? I have been told by some NVR vendors that I must choose which one I want to record and can't record both. That seems stupid - what's the point of dual streams then? By recording both, if I have an incident that I would like to examine more closely I should be able to review the MS locally, or very slowly remotely, and extract photos or clips at the higher resolution. The SS would be used for rapid review of many hours of recording, the MS would be for detailed inspection. One vendor, however, claimed they only recorded the MS but then trans coded the MS into a SS for remote viewing. Is that common or the best way?
Other NVR vendors say both are recorded simultaneously. Is there really that much difference in NVRs? As for the HikVision system described above I cannot seem to get a firm answer as to the recording aspect (one or both being recorded) or the viewing aspect (see next question).
2) In remotely playing back the recorded video some kind of client software must be used. I have examined a few and I am also confused about the playback of the MS and the SS. Some Web-based client Software I have examined does not give me a choice of MS or SS to review - it seems that only the MS or the SS is available depending on settings on the NVR. I would want to be able to choose which I want to review at the time of playback. If I wanted to review a time-period at high resolution I would then switch to the MS for the particular time period and examine using zooming, photo snap-shots, or clip extraction, all at high resolution.This would seem to best be achieved by recording both streams as produced.
One vendor told me they recorded only the MS but trans-coded the MS to a SS for remote playback. I'm not sure that is the best method. As described above I would want to choose SS for rapid review looking for incidents and I'd like to be able to Fast-Forward (FF) as fast as possible and it seems it would be easier to do this with an already recorded stream as it would only involve skipping frames whereas FF and trans-coding simultaneous might be harder - I don't know.
I tried to examine the HikVison client software on their site and the manual of operation doesn't seem to give the option of selecting MS or SS.
I have looked at other vendors and have seen some proposed client SW that does allow me to select MS or SS (one called Smart-PSS for example does). But I don't know if that Smart-PSS SW will work with the HikVision cameras or not. The HikVision cameras are so-called ONVIF compatible with both S and G profiles (not positive about the version but it seems very up-to-date). I'm not sure exactly what that means but how do I know if the Smart-PSS will be 100% compatible with the full set of features from the HikVision camera?
In general - I am confused about what the cameras provide, what the NVRs are able to do with what the cameras offer and what the client software will provide based on what the camera and the NVR can do; specifically for this thread with the MS and SS.
3) I am also confused about the capabilities of Motion-Detection (MD) with respect to the main-stream and sub-stream. If I enable MD does that enable it for both the MS and the SS? I would guess that the camera itself identifies motion using the high-resolution MS and would therefore be able to flag the SS at the same time that motion had been detected. But darned if I can find out. How does this work? Can I review the SS for MD events and then look at the MS for detail?
4) Finally, I am confused about recording parameters for the MS and SS. In setting up the MD parameters, in one case of NVR SW I examined, one is able to set up a "normal" or "regular" resolution and frames-per-second (FPS) for continuous recording but an entirely different resolution and FPS setting for a MD event. This to me makes a lot of sense. I would like to record continuously at high resolution but low FPS but upon a MD event record at a highest resolution and high FPS during a MD event. Is this an option? In looking at the offered settings I am usually offered only Continuous, MD or Alarm Event (AE), or MD & AE. I would very much like to do as I suggest - Continuous at high resolution and low FPS (e.g. 5 FPS) but have a MD switch to a highest resolution and high (30 FPS) situation and after the MD to switch back to the normal continuous setting. Does any system allow this? Does the HikVision system described?
I have been talking about NVRs. I notice a forum dealing with Blue Iris. Does this SW do what I am asking for? If so, does anyone sell a package of hardware and software for an unattended system like I am looking for?
Sorry for the length of this "question." But I have been thrashing around the web and this forum and can't seem to zero in on the answers to make a good decision or to find a system that does what I want.
Thanks for any help on these points in advance.
My questions:
