Ok I have done the google and looked about at the forums, I have the following... DS-2CD2432F-IW, this is the info I have for you,
DS-2CD2432F-IW
build date sticker 01/2015
Current firmware V5.2.5 Build 141201
Ok it Chinese, the vendor said it would have English on it, it has not........
He has sent me a file and some tools Hikvision TFTP Server, and it has two folders A and B....
I am connecting directly to the camera with and ethernet cable and a power supply. I am not using a crossover cable, just a normal one, I do not know if this is right?
I have tried this on a windows 7 laptop and XP, his instructions told me to to do this, (when I run SADP I get the camera show up twice, 1 for wifi and for the cable I think, I get 192.168.1.65 that I can connect to, and 192.168.254.6 that I cant?
1. Disconnect all network connection,include camera/wifi/router…
2. Change physical address to F0DEF1E352BD, local IP address to 192.0.0.128,gateway to 192.0.0.1 (when I Change physical (Locally administered address) address to F0DEF1E352BD the network adapter stops working, so I cant do that! this is on XP, why is he asking me to do this?)
then do cmd ipconfig /all well if I do what he says (disconnect all cables, I just get the media disconnected and (preferred ip address) when I plug the cable in and change the local IP address to 192.0.0.128,gateway to 192.0.0.1, then open TFTP I get,
TFTP Server 192.0.0.128 initialized, but it does not run...... what am I doing wrong guys (and girls) is there a better was to change this to english, if so what tools do I need. (please remember its a 2015 camera running V5.2.5 Build 141201.
Thank you
DS-2CD2432F-IW
Thank you
