greetings cam geeks,
i require an upgrade to my home security sentry lights in the form of a bulb camera if it is at all possible. my current (and old) setup is two lamps outward facing with a motion sensor in-between - see photos. this high point on the outside garage is also at OR beyond my home router wifi range. i am looking at this model bulb camera:
i know absolutely nothing about these bulb cameras or their reliability so i was hoping someone on this forum might help. i require no cloud service just the ability to download via bluetooth? only the pertinent images or video. one issue i have is that my outside garage lights are operated with a light switch and when on the motion sensor (see images) trips the lights on when someone goes by at night. must i tape over the motion sensor if i wish the bulb camera to work. likewise should i remove one of the lights and just use one receptacle for a bulb camera? and also tape over the motion sensor? climbing up to retrieve a micro card is out of the question, so i do need a cam with the ability to transfer the data to at least my phone or tablet via bluetooth and maybe wifi though the range is suspect. another issue is the aspect of the lights, they are angled outward horizontally, will this effect the ability of a bulb camera to work?
hopefully someone here has been confronted with my particular dilemma and can advise me how to proceed, suggest a bulb camera etc. also what size socket are my garage sentry lights?
thanks for any thoughts/ideas and a great forum
tws
tws
