catcamstar
- Jan 28, 2018
- 1,656
- 1,196
Nice diagram!
So if I read back 2 posts above, you cannot ping from 192.168.0.1 towards 10.15.2.3, is that correct?
This means that this "FAI box" cannot route ip traffic to that subnet (as the mitrotik should be able to do that). what is the routing table in the FAI box? I suspect only one gateway, and that's towards the WAN interface (blue line in your diagram)? And I also suspect that your VPN red line is going from the mikrotik over the modem3G over the internet towards the FAI box with VPN server? Otherwise you are creating a possible "spanning tree loop" with the VPN.
Last question from my side: if the 10.x network is your private private lan, do you really want your cams/smartpss having access to that LAN?
Thank you!
