Hello all, newb to security/cams here. I've done a bit of reading and searching, and could use some advice.
My house is in a rural setting 10 minutes from "civilization", and the county sheriff can be a ways off. I just built a metal pole building as a shop for my cars that is about 170' from the house. I buried a 1" PVC conduit when the gas/water/electric was trenched out just for any possible data or entertainment connection. The wifi reception in a metal building is always bad, so I had planned on putting a wifi router inside the shop and hardwiring it to the router in the house. My reading on that subject about the dangers of running a parallel metal path such as Cat5 or 6 between buildings (different electrical ground planes and the danger of distant lightning strikes frying components) has led me to purchase pre-terminated fiber optic cable and media converters to use as my data connection.
Then I found you people! I'd like to keep an eye on the place when not home. I initially thought that a cam system with some sort of motion-sensing alert sent to me would be ideal, but I've read some opinions on here that "a cam system isn't an alarm, if you want an alarm, get an alarm." So I'm open to getting an alarm also, but as I check a lot of false alarms in my job, I don't want the cops called every time the alarm is triggered. I'd like to get an alert, then pull up the cams and have a look around.
So. As I see it, my choices are run two separate 3-4 cam systems in the two buildings, or run the 3 cams I'd like in/around the shop to a switch, from the switch to the shop router, over the fiber optic to the router/internet connection in the house, where the house cams would also be connected with a switch to the router, then the router to the NVR. Will this work?
I'm very grateful for any advice. Frankly, there is so much good info (and jargon) on here, that it's tough for a new guy to sort through all of the options.
