I have a 9 cam system built around 2231 eyeball cameras and a Dahua NVR running for a few years at home with great success. I'm continually shocked by the performance.
I'm now looking to install a similarly sized system at work. It will be entirely outdoor and for general surveillance. No specific need for facial recognition or LPR. These will be 1st and second story mounted and generally used as both a deterrent as well as post issue/theft/accident review. Exterior of the building has very limited lighting so decent IR performance is important. I wish to use a NVR and stay away from blue iris or similar simply due to familiarity.
I have a significantly increased budget beyond what I had a home, so I'm quite interested in what is available with a an increased budget. I'm using this as well to learn the current state of the technology and may port it back into my home system.
With a $1000/camera budget and this rough overview what cameras would you consider? For aesthetics, I'm limited to eyeball or dome cameras. No need for varifocal as I can spec lense to suite. That said, I don't object to them if they are ideal.
Was planning on a 16 cam 8K Acupick NVR simply to support a potential 8K camera rollout, but otherwise am open to solutions.
any thoughs or suggestions within this budget?
Vin
Vin
