Picked these up on the bargain. Came with 2x 90 degree IF illuminators with swivel mounts and 12V DC transformers. Will most likely not use the power adapters but will use 5.5mm x 2.1mm male to male connector and power off camera. Like to mount minimum 4ft from camera to avoid flying insect motion recordings. Can get away with using lights on cams in winter as I'm north but have to shut off led cam lights come summer when insects are out in droves. Been using led 8w standard household yellow bulbs which have built in ambient light sensors where possible possible. Found these IF illuminators do the trick when no local power outlet or light fixture is available.
