I would suggest that you just get the AI working before you try to get the facial recognition and the license plates working all at the same time! Why put the :80 behind the object names, you already have the "min confidence" set to 80, did you download the required models for built in AI? is your driveway camera a PTZ, if not you do not need the "Extend trigger with PTZ movement". Do you need to have 2 triggers with in 10S on the motion sensor, I would turn on Highlight "Show object rectangles" so that you can see what is happening. In the To Cancel box put in " Do Not Cancel". Do you really need to send 40 post trigger images, I only send 3. You might want to reduce the confidence level until you get it working!
