Im totally new to this subject and have no equipment yet.
I was looking for an nvr and 10+ cams. Im not really sure what kinds of features and specs I should be looking for nor what specific equipment I need.
I know I want 10+poe cams. Maybe a couple wireless cams ran off ac power if the nvr would allow but not a deal breaker. I want all storage to be at my home and no sub fees. Would like an app or some way to look remotely live. Hopefully the nvr will have a user friendly ui.
Do you need a special kind of ethernet cable to run the cameras or is a cat5 I put together myself going to work?
What is a poe switch used for?
It appears you would use them to combine feeds to 1 cable to the nvr.
Is that correct? Or is there other uses?
The blue Iris things sounds interesting. It appears to be software installed on a computer that gets plugged into the nvr?
Is that correct?
Thank you in advance for any help or direction.
Is that correct?
