Hello everyone, just bought my first 2 Onvif cameras and I have so many questions. I've been reading though the forums, resource guide, and the wiki. The more I've read the more questions I have. I thought I'd just ask my remaining questions in noob section.
Thanks for any help
- Any benefit of using a managed switch and creating a VLAN for the camera system?
- Thinking about buying a cheap POE switch till I can afford a nice one. Would there be any issues with a cheap poe switch?
- How effective is a camera system if you just use the SD?
- Are files easy to view?
- Is there software that can manage whats on the SD cards?
- I see that Port Fowarding is bad. I have a Home Automation system that is port fowarded, I assume you would recommend I not do that?
- Is Blue IRIS better then using a NVR or NAS server like Synology?
- The computer I put Blue IRIS on is also used for gaming and Plex Media Server. Would that be to much for PC? i7-4930k with 32GB of RAM.
- Does Blue IRIS offer a API for 3rd Party integration? (Example: Camera detects motion, Home Automation Powers on outside lights, changes TV to roku and opens IP viewer app in Roku to display camera)
- I see that nvr's offer 12v triggers for Alarms. Is there a way to run a 12v trigger off of Blue IRIS?
- Anything cool I can do with onvif cameras? Just to give me some ideas.
Thanks for any help
