Hi guys,
I'm currently rewiring my mum's house and am installing outside cctv & hard wired internet to all rooms.
For the internet, as the house is large, I've run cat6 from each room back to the utility room where I plan using a switch to connect them all in.
From the switch, I'll run a cable downstairs to the incoming router hub.
For the cctv, I'm running a second cat6 from the main incoming router hub to the upstairs utility room where this will feed a POE Switch.
Off that POE Switch, I have run cat6 to x7 camera locations.
I would really appreciate if someone could confirm the wiring layout is ok please?
I'm suspecting I can do all this with one switch and one cat6 from the main router/hub up to the upstairs utility zone but i wasn't sure and besides a second feed upstairs could not hurt for future use if that was the case or it was safer not linked.
Sent from my SM-G955F using Tapatalk
