Hello everyone. We are trying out Blue Iris as an alternative to Clear2There software we are currently using. The cameras are all Clear2There cameras specs below. The server should be plenty of power as it does work fine with the clear2 there software (see specs in picture). The problem we are having is when all cameras are enabled. we start getting warnings about FPS mis-match. and when looking at the camera properties we see that the FPS has dropped to 2-4. The cameras are all set to 10 FPS. Disabling a few cameras stops the warnings from showing up on the remaining cameras. Attached are some screen shots of hardware specs and configs. I do have hardware acceleration on and all cameras are set to record direct to disk. I assume this is being caused by a configuration error on my part. Any help would be appreciated. Thanks!
View attachment C2TA71080IPOE.pdf
