New power cord for Dahua NVR (NVR4104-4KS2)
tomas21
Aug 12, 2014
186
30
US
Does anyone know a model on Amazon that will replace our power adapter for the Dahua NVR (NVR4104-4KS2)?
The specs
input: 100-240V 50/60Hz max .7a output 12v 2.0A
Most 12v DC power supplies are 5.5mm x 2.1mm, this one fits 5.5 mm x 2.1mm and 5.5mm x 2.5mm, is UL Listed, has great reviews and is reasonably priced. It also meets or exceeds your other specs. On amazon ==>> here.
Thank you.. I was checking out the one you listed as well as this one with sideways plug
That one also would work well. It has the size connector that is most common for 12VDC cams, NVR's, routers, modems, etc. which is 5.5 mm x 2.1 mm (inside barrel). That is most likely what your NVR is but if you can confirm that then go for it.
Physically larger and has higher current capacity but if you prefer the small, separate AC cord plugged into outlet vs. a 'wall wart' that can take up space, then it should do the job as well. It's also UL listed.
