Hello and thanks for letting me join.
Sorry for a long post for my first one but this is doing my head in now and I need some help.
I have a Hikvision DS-7608ni-i2/8p which developed a fault where at random intervals it would freeze and then restart.
At first it would be about every 10 to 15 mins.
I had been updating my firmware over the years and wasn't sure if the reboots started with the newer versions.
I rolled back my firmware to 3497 but the problem still occurred.
PoE power is 17.2W with 102.8W remaining.
Fault still happens with HDD and all cameras disconnected.
Did factory default and Init HDD, still same.
I setup a Picolog data logger and monitored all the voltages from the PSU and they are stable.
Some capacitors on the board were swollen so I changed all the caps.
It has now become more stable and the fault is now predictable. It now will record all day, if left alone but when I log in, I can guarantee it will freeze after entering PW and hitting login for the first time.
After that it will restart and let me log in for maybe 20 to 30 mins before freezing again, I have managed to install all updates sequentially, up to 4.51, with no improvement to the fault.
Strangely, it also restarts EVERY morning at between 8:58 and 9:00AM, then is good all day, does this suggest anything?
Thanks for any advice or alternative suggestions for a replacement.
Tony.
Tony.
