Hello everyone,
I have stumbled onto this forum looking for answers. Currently I am using 16 channel dvr system that I had installed 15 years ago for my store that is showing signs of going out so I'm in the market to upgrade them.
I know I want to get BI and 16 4k or possibly 12MP cameras to upgrade to.
What I'm getting confused is if I record 24/7 in highest quality and have live view of the cameras during store hours, is the encoding only for the sub stream I'll be viewing while it's on the tv screen or is the whole 16 main stream (being recorded) + 16 sub stream (being viewed) use up the cpu to encode.
I was thinking of getting maybe I9 - 13900 and use the intel hardware decode if the recording is also getting encoded.
If the direct recording is not being encoded and doesn't use up the cpu then I would like to know a good range of the cpu I should consider.
I do want to lower the power consumption as much as possible to be not have to cool the system as much. The area where the pc will be located is really dusty so I really wanted to build a fanless pc setup.
If I can confirm the cpu is not being used to encode the high quality main stream that is being recorded then I think I would have a better idea of the system I should build.
Cameras I plan on getting are Reolink 4K Duo 2 PoE, 4K RLC-820A and 12MP RLC-1224A
Thanks for any input in this matter.
(plus look at the blur on the face and he is barely moving and this should be ideal indoor IR bounce and it struggles):
. I read Reolink: Deconstruction of a dangerous misleading youtube reivew, now I have better understanding of how these cameras work. Thanks alot
