I’m going to be installing a security camera system for the first time. Very new to this world (just joined this forum a few days ago), I have a Reolink system arriving today that I don’t even plan to open and will just send it back due to several hours of reading on here and all the negative reviews. It looks like Dahua from Empiretech is the way to go. So far, I am planning on 4-5 outdoor cameras but from what I’ve read I should go ahead with a 16 port NVR for future expansion. Below is what I plan to purchase along with some questions. Let me know if anything jumps out at you or have any better suggestions.
- NVR16CH-16P-2AI
- It doesn’t appear to come with an HDD so I’ll have to purchase and install separately correct? Looks like WD Purple is the go-to. Probably 4 or 8 TB
- IPC-T54IR-ZE-S3
- I plan to purchase just one and move it to different corners of the house to see what focal length is needed for that location (I’ll probably just end up with 4 of these and call it good)
- Garage to the street is about 60’ so I may need a bullet style cam with more than 12mm to ID
- Any good reviews or thoughts on the IPC-Color4K-T or IPC-Color4M-T?
- Any issues going with vandal proof version of these cameras?
- Front door/doorbell camera
- Not sure if I should just install a camera here or an actual doorbell camera?
- Amcrest AD110 for the doorbell or IPC-E541F-E2-AS for just the camera
- Is the Amcrest compatible with the Dahua NVR? Plug and play?
- I am going to ask this, but I think for someone like me I should stick with the NVR. Blue Iris vs NVR???? What can Blue Iris do that the NVR software can’t?
- Basic questions
- Understandably you can have the best cameras but if you don’t have the settings right it won’t matter, so…. Does anybody have a “go-by” or good list of setting to start with for both the cameras and NVR? Shutter, exposure, bitrate, etc. For both day and night.
- Once everything is set up, I should be able to have the NVR plugged into my TV via HDMI to view the cameras, correct? No special app is needed for that.
- What app is recommended to view the cameras on an iPhone?
- Initial setup on the NVR will be done with the mouse and screen/TV. Then all settings and adjustments for the NVR and cameras will be via a PC running Smart PSS Lite software on the same wifi network. Is this correct?
