- Apr 29, 2016
- 19
- 2
So i was one of those poor souls stuck with Satellite internet which is the worst and most unreliable service available. Recently, a new ISP provider offered fixed wireless service with better upload and download speeds, much lower latency, and consistent speeds/service.
I was super excited but I have run into an issue.
Their modem is also a router and they will NOT allow me access to the router, nor will they set up DMZ for me. Not sure how I can port forward in this situation.
Configuration is a their modem/router to my TP-Link AC1750 router. Then ethernet to my NVR, Computer, etc.
I have a double Nat issue as my TP Link router is getting a local IP for the WAN address.
I have read that putting my TP Link into AP mode might work, but if i can't port forward on the router/modem I don't see how this will help.
Oddly enough, and this is probably just because I don't understand how these things work, if I set my NVR on uPnP and using the phone app use serial number instead of IP address I can view the NVR cameras. While this helps, it is not the solution for me because I only use an NVR for 8 of the cameras. The rest are all just Blue Iris and my preference is Blue Iris because of its functionality as well as all cameras can be viewed through there.
Any suggestions would be appreciated at this point.
Please don't suggest I go back to Xplornet. I despise that company with a passion.
