New invention idea for Spider webs near external IP Cameras
sharpharp
Nov 26, 2014
100
5
Since owning IP cameras and using them outdoors, I've always had problems with spider webs obscuring the video.
Tried simple techniques like clearing the webs every week, Spider-x (only works for a few days) and even a separate Illuminator away from cam, but here's an idea.
I have a spare POE switch and cable going next to my IP camera. Is it possible to build a spider repellant buzzer (like those indoor ones which give off a frequency which makes bugs run a mile) which will run from the voltage from a POE switch Ethernet cable?
Any ideas, just thinking of ways to remedy this issue once and for all
Just spray the area with mint soaked in water, spiders hate mint and won't make webs near it at all.
Reactions: vasycara
Some cameras, including the two Hikvision models I have, let you turn off the internal illuminator. When I did that, relying only on a separate illuminator several feet away, there are no more spiders (at least, in front of the camera; it looks like a haunted house right in front of the light).
Reactions: Flintstone61
Those don't actually work.
x2 those are a power wasting gimmick; do some research.
external IR only works if you disable the onboard IR too.. if its still running it can just attract more bugs and spiders as its just adding more light to lure em in.
Ive been using petroleum jelly smeared around the camera lenze body for the past couple of years and it works well.
It's cheap and wont wash away in the rain.
I know I’m about 10 years late to this thread , but I found it while searching for other people dealing with the same problem.
I install CCTV systems in Ireland and spider webs have been a constant headache, particularly with built-in IR at night. I tried the usual sprays but never had much success long term.
So I actually ended up building something very similar to what this thread was asking for — a small automatic “wiper” that mounts under the camera and periodically clears webs from in front of it without touching the lens.
This is the prototype/product I’m currently testing:
Automatic Security Camera Spider Web Remover | Spider Wiper
Funny to find a thread from 2016 asking for almost exactly this. I’d be interested to know what you guys think of the approach.
Thats 4
