CCTVCam
- Sep 25, 2017
- 3,041
- 3,939
Helped catch this one. We were able to match him to a burglary in another development the same night.
Great quality. Which camera was in use?
I had a brief intro/walk through with the guy today and he was pretty helpful. He said his pricing is kind of firm because he has to kick some money back to the builder (not sure if this is accurate). For the 2nd floor I am asking them to run conduit (should I go with 2 or 1 inch?) into the attic and have it terminate where I can reach it standing up. -Doing this, I should be able to run my cables up to the attic and down the conduit that runs into the basement
(2) 1.5" conduits might be easier to install than (1) 2". Conduits between floors will need to be fire sealed.HI Tufan,
Yes - the main builder iirc typically gets 10-20% markup.
1 " will be too small imho - I did 2x 1.5" pipes - but my place is a lot smaller. Will depend on how many cables you are sending down the tube, definitely error on the side of a more area in the conduit.
meh conduit is the only thing that's future proof. Unfinished basement == 2/3 of the house is fairly easily accessible after construction.Holy smokes!...
I have not thought too much, but looks like there's potentially a LOT more low voltage wiring for the "smart home" ...
If you’re doing a new install, you should put in power lines, two CAT6 Ethernet cables, HDMI, coax cables, and phone jacks to every “entertainment point” as a minimum. And make sure you still leave some empty conduits for retrofits in the future.
3. Home Automation Cables
I’ve just listed a number of entertainment needs, but what about home automation?
Experts generally agree that you should install a CAT7 cable to every sensor point in your home. That includes thermostat temperature sensors, presence detectors, smart switches, water detectors, and so on.... "
Ref:
6 Vital Ways to Future-Proof Your Smart Home
( I'm not too certain about phone jacks and coax... guess conduit would be the way to go... )
