Hi guys,
Im new to this whole POE security camera system. So I am here asking for feedback from the experts =-) on what the setup should be and get some questions answered based on your guys feedback and experience.
My top priorities are
1. Longevity of the system
2. Image quality
3. Power consumption
4. Price (camera between 60 to 130 each)
5. Not impact current home network
Camera placement Setup
So below is my thought of what the house setup should be. I want to be able to capture as much as possible from the front, side and back of house. In total i count 12 camera and I think that is alot. I was hoping only 8 but that does not seem to be the case lol. it is a single story 2800 sq ft house and my lot is over 9000 sq ft.
I am thinking of using 4mm lens for all camera. Please provide feedback if that is a good choice or not? Also the placement of camera to cover what i need.
Camera Selection
So i am torn between bullet camera and dome camera. Anyone that can provide feedback on this based on my proposed above setup?
Below is the options I was thinking and hoping to get folks feedback on which would be best for the things I am trying to accomplish. I was going toward Dahua for the lower power consumption. I am also looking for a camera that has great hardware motion detection as I only will have a i5 CPU. Will share more below.
Hikvision DS-2CD2032-I CCTV POE 3MP Bullet IP HD Security Network Camera, 4mm
http://www.amazon.com/Hikvision-DS-...UTF8&qid=1460570587&sr=1-1&keywords=Hikvision
Power Consumption: Max. 5 W (Max. 7 W with IR cut filter on)
Or
Dahua IPC-HDW4300C Waterproof 3MP IP66 IR HD Network Mini Dome IP Camera POE with Audio
http://www.amazon.com/Dahua-IPC-HDW...ef_=sr_1_2&refinements=p_72:2661619011&sr=8-2
Power Consumption:<6W
or
Power Consumption :Max 4.5W
Site purchase feedback
I am trying to figure out if I should fork up the cash and purchase all from Amazon or purchase from aliexpress. based on the # of camera I want/need there will be big cost savings and that will save but I dont want to save in the effort to cost issues down the road. So I feel I am somewhat tech savvy. I have my own Kodi SQL db, my own 30TB sysnology Nas and my home automation media servers. I know basics telnet and sql commands. I did some reading on upgrading the aliexpress firmware. What I understand today is the aliexpress camera are chinesses products and they hack them to load a English firmware. I see some that are English firmware, some multi lang. Some say they provide firmware updates for future and some dont mention anything like that.
So my question is will I really need to update firmware? Do i get added benefits for future?
How often do you guys update firmware?
What are you thoughts on what path should i choose? save money = some hassle or spend more money = no hassle???????
Anyfeedback on current sellers or experiences to use for Aliexpress or another site?
Network / PC Setup
So I do not want to impact my current home network as there will be alot of traffic with 8 plus POE camera. SO below is what I drafted.
My idea is to have a separate network for POE camera and seperate home network for internet traffic. I plan to manually set a IP for each camera as there will be no DHCP server that connects them.
Below is the POE injector I plan to buy and connect to a basic 100 mb hub.
WS-POE-8-48v60w Passive 10/100 Power over Ethernet PoE Injector for 8 IP Cameras, VOIP Phones or Access Points, 48 volts, 60 Watts Total Power
http://www.amazon.com/WS-POE-8-48v6...e=UTF8&qid=1460569613&sr=1-3&keywords=poe+hub
Will this plan work?
Has anyone setup their network like this before?
Any changes or recommendation you guys want to share?
BLUE IRIS software
So I plan to have blue iris on my PC. I have read based on the camera I want it will be heavy on the CPU load. My plan is to have all camera record based on motion for 24/7. I do plan to use the blue iris mobile app to get access on the internet via my andriod phone.
Based on my CPU/PC setup, will that be enough?
Would it be better to use hardware motion detection on the camera to save on CPU usage? = Less power consumption?
Should I use the Camera security software? I heard good things of the Hikivision software and read it uses way less resources on pc. Not sure about Dahua. Thoughts?
So i gave alot of info above and I am trying to see If I am missing anything and what I should change before I start making the necessary purchases. It will be over a grand setup and I am trying to limit my surprises. So any feedback and help you guys can give me would be awesome.
Thx you in advance.
2. Image quality
Camera Selection
Or
or
Network / PC Setup
BLUE IRIS software
Thx you in advance.
