mat200
- Jan 17, 2017
- 17,444
- 29,416
Thanks mat200! Your explanation is extremely helpful.
For a new construction exterior wall, the junction box would screw onto wood, and then stucco (or other finishes) around it, I assume.
For the wall mount, how would that work? Attach directly onto stucco? I don't see any finish lines on it to accept stucco if it were attached directly onto wood framing.
Possible options:
1) Stucco first - leave hole for cat5e/cat6 cable - then mount junction box on stucco and pull wire into junction box
This works good if you decide to change the form factor of the camera later, as each form factor uses a different junction box.
2) Stucco after installing junction box - this may get tricky - depends on your stucco crew - as now they have to work around the junction box and do a good job. This also will force you to keep the same form factor for the cameras in the future.
3) Put an 1 gang electrical box in place and stucco afterwards, add camera junction box after. - as the junction box or mount may not fully cover the 1 gang box you may need to put a 1 gang cover plate on the electrical box and then put the junction box on top of that. ( This works ok if you decide to change the form factor of the camera later, as each form factor uses a different junction box. )
If you orient the 1 gang box horizontally it would work better with one of the wall mounts like the PFB204W
PFB204W | Dahua Technology - Dahua Technology
I would be tempted to do option #1 or #3 - as stucco crews should be well skilled with those jobs already. Certainly discuss this with your builder as they should have some good experience with this.
Thinking more about this, the building will last 100 years or more... the form factor for cameras probably will change by that time, so definitely either option (1) or (3).
