- Mar 9, 2014
- 36,891
- 21,411
DS-2CD2D21G0-D/NF
2 MP Indoor Mini Network Camera
DS-2CD2D21G0/M-D/NF
DS-2CD2D21G0/M-D/NF
Why not one with a SCREW shape. ..
likely because it would add to its size. They have other units with a base station that supports poe. You can also simply use an active poe splitter.Why not POE?
It make sense to have POE. Pin hole usually installed in remote location so that is why I wonder. I know that Axis have something similar. I also know what you think about Axis hehelikely because it would add to its size. They have other units with a base station that supports poe. You can also simply use an active poe splitter.
hikvision and dahua have the same type of unit axis does with POE as well as SD card, alarm and audio i/o. Axis does not have a tiny pinhole without the base station like these units.It make sense to have POE. Pin hole usually installed in remote location so that is why I wonder. I know that Axis have something similar. I also know what you think about Axis hehe
CovertYes I know which makes it more expensive. Do you have the model number for the Hikvision pinhole with the PEO?
