- Jul 18, 2016
- 17
- 2
I just purchased some Hikvision DS-2CD2387G2-LSU/SL 8MP ColorVu Network Turret Camera With Live Guard 2.8mm. I have a 7716 m4 nvr on order and 2 6tb Skyhawk drives. I questioned if AI or purple pro would be better but the seller said standard Skyhawk are fine.
I will probably go up to 8-10 8mp cameras. Will standard Skyhawk drives be adequate, or should I be looking at the AI or WD purple pro models? I haven't collected the drives yet so can probably change my mind.
The cameras will be used in a small retail environment. The seller said color vue probably wasn't needed and may cause glare? They said they are mainly for outdoors. If there are any issues I plan to add more cameras later so can move them around. Are colour vue not recommended for indoors? I plan to mount 3 cameras in a room that is 9mx4.5m and one camera in a room about 3mx3m.
Also does anyone have any tips in installing the cameras to a 600x600 false tile ceiling with a hanging metal grid? The cameras are heavier than I anticipated. I was going to get some mdf backing board unless there are better methods?
Thanks in advance.
Thanks in advance.
